Sky HD now fitted, TH42PX70 picture advice needed
Discussion in 'Plasma TVs Forum' started by JonA4, Sep 22, 2007.
  1. JonA4
    JonA4
    Hi, I've just had Sky HD installed today. Has anyone got any suggestions to get the best out of my Panasonic TH42PX70?
    The HD picture looks stunning, Just watching King Kong and it's amazing.
    Is the Sky HDMI cable any good or is it a cheap one?
    I'm using an optical lead for the surround sound, and it does sound good even without a sub (as it's being repaired)!
  2. GerryH3
    GerryH3
    Sep 17, 2006
    578
    28
    Edinburgh
    +62
    The cable that Sky supply is fine.
    Try playing about with the Output settings in the Sky System Settings/Picture menu to see if you can notice any difference between 1080i or 720. I've tried both and can't see any real difference between them, so I usually have it set to 1080i.
