Sky HD - no sound via optical when used with switcher
Discussion in 'Sky Digital TV Forum' started by Moley UK, Feb 27, 2014.
  1. Moley UK
    Moley UK
    Dec 26, 2011
    156
    +21
    Hi all. I've been trying to search the web for an answer to my problem, but can't seem to find one.
    Right, here goes.
    I have a Samsung Blu ray 5.1 system which has one optical input.
    I have an Xbox 360, Xbox one and Sky HD box which I would like to connect to the 5.1.
    I have bought an optical switcher which allows the 3 devices to be connected to the 5.1 individually with a turn of the switch (1,2 or 3).
    Both xbox machines work as they should via the switch regardless of what port they're in. Sky on the other hand, doesn't want to know.
    I've tried all combinations of cables in and out and I can't get it to work. The switch is fine (all ports work).
    Sky only works when connected directly to the 5.1 and not through the switch.
    Any help/or advice??
    I'm massively confused as to why this wouldn't work! All sky settings are set as they should be.
    Many thanks in advance.
  2. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Does your Sky box have a co-ax digital output and does your Blu Ray system have a co-ax input? If so, use that for Sky. (Your Sky optical output is not strong enough to survive the losses in the optical switch.)
  3. Moley UK
    Moley UK
    Dec 26, 2011
    156
    +21
    Thanks for the reply.
    Unfortunately, the 5.1 doesn't have a coax input.
    Is the Sky box optical really that naff that it can't go through a 6 inch switch?! If so that's really bad.
  4. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    They are built to a price.
  5. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    It used to work on a switch for me, but Sky machines are notoriously fickle.
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,751
    The Borders
    +3,519
    'I have bought an optical switcher which allows the 3 devices to be connected to the 5.1 individually with a turn of the switch (1,2 or 3).' - and like many folk you find that switch is not such a great design, you may want to return it and try another sample or try a different design of switch.
    Joe
