sky hd no sound (surround sound)
Discussion in 'Sky Digital TV Forum' started by Scottburden82, Jan 6, 2012.
  1. Scottburden82
    Scottburden82
    Jan 6, 2012
    5
    Hi, I really need some help please.
    My issue is, I have connected a Panasonic 3d blue ray surround sound system up to sky, using a optical lead. I get sound through the system on normal channels but get no sound at all on the hd channels. I can turn up the tv and get sound through there but nothing on the surround system.
    Iv looked everywhere for answers so any would be greatly appreciated
    Scott
  2. John
    John
    Dec 13, 2002
    11,461
    +3,088
    Have you switched DD on in the settings menu ?
  3. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    Hi and welcome to AVF.
    A couple of things to check - in the Sky menu what type of audio output is selected, and in the sound system's menu what type of audio input is selected?
  4. Scottburden82
    Scottburden82
    Jan 6, 2012
    5
    Hi all, on the sound settings audio output is set to stereo and digital audio output is set to dolby d
  5. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    Do you get a red light coming through the optical cable?
  6. Scottburden82
    Scottburden82
    Jan 6, 2012
    5
    Yes I do get a red light. Its strange as I get sound through the surround sound but not on any of the hd channels.
  7. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    Also please edit your double post.
  8. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    Your Panasonic home theatre is set to expect PCM input only via its optical, rather than set to Auto which means it will correctly decode both PCM and Bitstream (Dolby Digital and DTS) input, should it receive it.
  9. Scottburden82
    Scottburden82
    Jan 6, 2012
    5
    Is there any settings I would have to change on the surround sound to make it work?
    Thank you
  10. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    I've asked what the current settings are on the sound system, and Broadz has just suggested what setting you might need to change.
  11. Scottburden82
    Scottburden82
    Jan 6, 2012
    5
    Sorry actually got it working now. Thanks for your help.
