Quantcast
Sky hd no signal in caravan
JOJOJON
Have sky hd in touring caravan
after a power cut have no signal. Have another box but the same. When i fit a old box with a single feed it works ok
my dish is a oyster full auto dish any help please
SIMNANI
Check both feed with old box if is both feed is working with old box then u need to change box.....
JOJOJON
No both hd boxes work ok at home it is only in the caravan after a power cut they do not work.
The standard box will work ok on both feeds
