Sky HD & Magic remote eye
marty123
has anyone else not been able to use a standard remote control to control sky hd through a magic eye. The magic eyes worked fine before hd was installed. now the magic eye won't sned sky remote or sky hd remote down it.
Any ideas??
martmiller
Any ideas??
just a thought... have you checked that the setting for power on RF2 is enabled? The default is for it to be disabled. services 4-0-1-select and then the RF2 power option.
also have you checked that the mgic eye is plugged into RF2 and not RF1, as RF1 has no power.
Good luck
Mart
mr. shr
Any ideas??
When you say "standard remote" do you mean a Sky remote, or a SkyPlus remote?
The magic eye only controls an HD box with a SkyPlus remote.
BandWidthJunkie
I'm using a Sky Plus Remote and a Sky TV Link with no problems :smashin:
Similar threads
