mo said:
parmMann,
i am just about to look into connecting up a second tv via magic eye.
could you tell me how you did it , it would be a lovely favour and save me time.
thanks in advance
Hi Mo,
I didn't actually setup mine myself, I had the aerial people do it for me. As I was moving into a new house, the aerials and everything had to be installed so I got them to wire everything up.
However! I can tell you the basis of what they've done.
The Sky+ box is downstairs, the second output from the box goes through the wall, up the outside of the house, and into the loft. In the loft we have a booster box, the Sky cable plugs into that. The booster box then has 8 outputs which can be connected to different TV's/Aerial Sockets.
One cable from the booster box runs into my bedrooms aerial socket. I then have the aerial from the wall connected to the magic eye, which connects to the TV. This allows me to change channels in my room.
Sorry I couldn't be a bit more detailed on how to do it, as I didn't set mine up, I only know the general setup. I hope thats enough to get you started, and I'm sure a lot of the users on this forum will be able to help you further should you need it.
Good luck with your setup!
