PhilGreg
Hi I've an old Sky+HD box and it's just started to lose channels, specifically channel 5HD, sky 1, and most of other sky channels. These either break up or show no signal.
I have an LG TV with freesat input so I've disconnected the sat cable from the sky box and connected to the TV and channel 5HD works perfectly. I've put the box in single tuner mode and connected one cable at a time and both have the same problem.
To me this rules out the LNB and cabling.
Is it likely to be the box? Is there anything else I can try? I don't want to pay extra for sky Q so will either have to buy a second hand box or cancel. Thanks.
