Sky + HD installation
Discussion in 'Sky Digital TV Forum' started by viru, Nov 29, 2010.
  1. viru
    viru
    Nov 29, 2010
    You may have this question already.
    I have a new property build the wiring was done as follows:
    2 wires left outside- 1 for Sky & other for the TV aerial running into the utility room.
    The Utility room has 9 cables 4 for sat 4 for TV (coming from 4 rooms) and 1 for CCTV
    The sky installation guy has used both the cables to connect the dish as SKY HD needs 2 cables
    My question is is there any kind of Junction box / splitter available by which i can use the feed from the Dish and distribute the signal to all the rooms.
  2. logiciel
    logiciel
    Feb 2, 2008
    53,136
    UK
    +5,775
    The room where the Sky receiver is can have both Sky and terrestrial analogue and digital down one of the cables that the Sky guy used - it needs a device to combine them and another to uncombine them, that others will tell you about.
    The other rooms can have terrestrial through an amplifier and splitter from the aerial.
