Sky+HD Installation Query
O
olympic_torch
Evening all.
I am currently on the waiting list for Sky+HD.
We have recently purchased a new TV and i want to tidy all the cable away.
When the HD box is installed does the engineer replace the existing cable that runs to the sky+ box or is it the same cable.
If it's a new cable then i wont bother tidying up yet.
newboy2008
You will be connecting your HD TV to your SkyHD box via a HDMI cable.The scart lead in use for your Sky+ box will not be needed.
Espada
They will not replace the cable from the dish if you have Sky+. I got rid of the old Scart cable after the HD was installed and now just use the HDMI input. The box does come with a perfectly adequate HDMI cable so you won't need to buy one.
O
olympic_torch
Thanks.
It was just the feed from the dish i was worried about.
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
