Sky Hd, HTPC and Blackmagic intensity pro capture card
Discussion in 'Home Entertainment Computers' started by Shock_xe, May 29, 2008.
  1. Shock_xe
    Shock_xe
    Firstly Hello all, Right im not gonna bore you with tons of spec/info just the facts as i need help and cant find the info anywhere, I have a HTPC with Black Magic Intensity Pro Capture card connected to Sky HD Through Component leads.
    How the Hell do I get a picture as all I want to do is forward it to mutliple pc monitors around the house, i have tried vlc player/adobe premiere/black magic software and cant even get a picture
    All help appreciated
  2. Shock_xe
    Shock_xe
    anyone??
  3. THX Jedi
    THX Jedi
    Apr 23, 2003
    10
    Hi, I am looking to do the same, did you ever get this resolved ? Thanks
