MoneyBagger
Established Member
I've been having some problems trying to get my Sky HD set up via Cat6 ethernet cable and a HDMI extender (admittedly a cheap one).
I initially had a 15m or so run of Cat5e cables set up, however in 1080i mode I was getting flickering so I ordered some Cat6 shielded cable. I've replaced the Cat5e cable with Cat6, however when I was getting no signal at all in 1080i mode. I tried re-terminating the Cat6 cable a number of times (which is a real pain!) and bought a cheap ethernet tester - which doesn't show up any problems.
If I change the Sky HDMI mode to 540p, I get a picture which suffers from flickering. But 1080i, I get no signal. I'm in a worse situation now than with the Cat5e cable!! Is it a problem with the cable, my termination or interference? Thx
