Sky HD hardware differences
Discussion in 'Sky Digital TV Forum' started by sneakers, Jan 7, 2012.
  1. sneakers
    sneakers
    Jan 7, 2012
    2
    Am probably going to join Sky for the F1 this year and noticed that there are two HD set top boxes to choose from. Aside from the disk space and price are there any other notable differences such as menu speed, PQ, connectivity etc?
  2. logiciel
    logiciel
    Feb 2, 2008
    53,020
    UK
    +5,729
    Welcome to AVF.
    There's one Personal Video Recorder, and that's available with the choice of a 500gB drive or a 1.5tB.
    There's also a receiver, which is issued normally for multiroom installations.
    HTH - Logi.
  3. sneakers
    sneakers
    Jan 7, 2012
    2
    Thanks. So the 1.5TB version is the same box just with a bigger hard disk?
  4. logiciel
    logiciel
    Feb 2, 2008
    53,020
    UK
    +5,729
    As far as I know that's correct, though they might be different colours - they certainly do exactly the same thing in the exactly the same way.
  5. Trollslayer
    Trollslayer
    Feb 11, 2007
    22,938
    Poole
    +8,623
    Yes, everything else is the same.
