sky hd extention cable
Discussion in 'Sky Digital TV Forum' started by Welshorp, Apr 28, 2007.
  1. Welshorp
    Welshorp
    Apr 2, 2007
    40
    I had my sky going into a 4 way split extention. I have now got it going directly into a plug and its working again.
    This seriously can't be a problem can it?
  2. JayCee
    JayCee
    Jan 20, 2004
    23,758
    Lanarkshire
    +2,570
    You need to explain yourself a little more clearly.
    What do you mean by a "4 way split extention"? :confused:
  3. Welshorp
    Welshorp
    Apr 2, 2007
    40
  4. bluedoo
    bluedoo
    Dec 13, 2002
    405
    +15
    do you mean that it did not work when plugged into the extention but works fine when plugged directly into wall socket
    if so i have heard they can be a bit fussy with voltages and it could be a problem and needs to be plugged into wall socket
  5. JayCee
    JayCee
    Jan 20, 2004
    23,758
    Lanarkshire
    +2,570
    If your Sky HD box works okay when plugged directly in to the 13A wall socket but not when plugged in to this extension...the extension is faulty...no ifs or buts...it's faulty...end of story.
    Some of the cheaper trailing extension sockets are poorly made and do not make good contact with the pins of the plug.
  6. DYKO
    DYKO
    Nov 28, 2006
    14
    3
    Did you try replacing the 13amp fuse in the extension in case it has blown
