SKY HD Coming Thursday!
Discussion in 'Sky Digital TV Forum' started by William YZF-R1, Feb 9, 2009.
  1. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Hi,:hiya:
    My first time in this part of the Forum, as the title suggests HD arriving on Thursday.
    I thought I would take some time to read up on Sky HD as Sky will be totally new to me, it seems that I should try and get a Samsung box.
    Spent some time today sorting out the input assignments & a label on the Receiver and finally hooked up an optical cable in readiness.
  2. Delvey
    Delvey
    Jul 20, 2008
    9,294
    Manchester
    +2,928
    Dont be fooled by the samsung box, there seems to be a few failing. The amstrad seems to be the norm. I got one and am not worried, my last amstrad sky box lasted 5 years, and my nanas is over 7 years old. And make sure they update the software over the air. They didnt do this with mine and another forum member so had problems pairing the cards.
  3. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Thanks, personally I have a problem with anything made by Amstrad, I am old enough to remember when they made cheap stereos etc.
    However, I will try and keep an open mind as Amstrad may be all they have on the van.
  4. Naaktgeboren
    Naaktgeboren
    Jul 13, 2007
    8,942
    Kashyyyk
    +7,539
    I agree, I cannot find many complaints about the Amstrad systems. I have been scouting all over and it seems that, the following boxes display the following problems.
    Thompson - PSU + faulty capacitators
    Samsung - Prone to loosing tuners
    Amstrad - Build quality??
    At the moment, I am hoping for an Amstrad although I am sure by Friday (my fitting date) I would have changed my mind again.
  5. Delvey
    Delvey
    Jul 20, 2008
    9,294
    Manchester
    +2,928
    and make sure he does a sytem update. Yeh there seems to be specific problems for each box
  6. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Thanks, the whole Sky thing seems a lot to take on board.
    Its a shame it needs double coax as I have a fitted sat socket in the wall and the single wire disappears up through the internal walls and reappears in the loft.
    Would have been very neat but no amount of gentle pulling initiates any movement. Would have been nice to pull a double through.
    Pulled the TV out today and sorted out remainder of the leads. So now the optical,mains and HDMI are all plugged in ready.
    If I do get a choice I will ask for a Samsung.
  7. newsagent
    newsagent
    Mar 9, 2005
    868
    28
    +42
    How long does a system update take and can you do it yourself?
  8. charliegirl
    charliegirl
    May 18, 2008
    113
    Just be prepared to be blown away - we had HD just after Xmas and are still amazed by some of the pictures.
    Hustle looks amazing as does Lost........shame the last ever series of ER isn't in HD though...seems a waste.
  9. Delvey
    Delvey
    Jul 20, 2008
    9,294
    Manchester
    +2,928
    system update doesnt take that long. and yeh the PQ is stunning, especially for sport,i watched the pro bowl the other night, and WOW
  10. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    I've avoided Amstrad kit for years but the Amstrad HD box is a decent piece of kit. I read all the threads about which boxes are better etc.. but havent had a single issue with the Amstrad box.
    SD and HD both look good, no lipsynch issues and the box is nice and quiet.
  11. tigertim
    tigertim
    Jun 23, 2005
    30
    Hi there peeps. Not wishing to hijack the thread...but I have ordered the 49 squid deal, and am told by email that 3 - 6 weeks is expected delivery time.
    Does anyone know the dimensions of the Sky+HD box ( I assume they are all pretty much the same ) as I would like to prepare the housing for it - I do know its a bit taller than my Sky+ box I have now. If someone could post the height of the highest box, then that covers me if I get a smaller one IYSWIM .TIA:smashin:
    I am expecting delivery today of a new LG 32PG6000 Plasma set, although most if not all of my HD viewing will be via a Sony projector and 8' screen.:D
  12. planetse
    planetse
    Dec 8, 2006
    876
    43
    +128
    You got thanks for that post because too many people on the forum are getting wound up over what box they must have from Sky. They all have problems if you read this forum; why? Because nearly all the time people only comment on things that are going wrong and are looking for a fix of solution. This tends to lead to people thinking they must have this or that or they will be doomed to problems.
    What a load of tosh. If Sky had a very high fail rate of a product then a recall would be issued or that brand would be taken of the market. You box is under warranty for twelve month minimum, if you have problems (like can be found with any electrical/mechanical item from mobile phone to a new car) they will fix it. Every one stop going on about this and that box get of the forum and enjoy your Sky HD.
    Still waiting for my box and could not give a chuff what it is as long as I get my HD viewing as anticipated and advertised.
  13. planetse
    planetse
    Dec 8, 2006
    876
    43
    +128
    Give it as much room as you can. Putting Sky boxes inside TV cabinets and the like without loads of ventilation room round them or sticking them ontop of amplifiers, causes most of the problems folk come across.
    Take a look at this half way down for box size.
    http://www.radioandtelly.co.uk/skyhd.html
  14. bigjohn
    bigjohn
    Dec 31, 2008
    32
    Beverley
    I found by far the best SKY HD picture using the LG 32PG6000 TV is achieved by setting the sky box to 720p and the LG 32PG6000(1024 X 720) to "just scan" not "16:9"
    The LG 32PG6000 is a great TV but the default settings are rubbish.
