Sky HD & coaxial cable
Discussion in 'Sky Digital TV Forum' started by leedsfireman, Sep 13, 2005.
  1. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,191
    38
    +3
    Does any body know if the same coaxial cable will be used or will it be different. As i'm just doing my room out & trying to put cables in wall ready.
  2. gbmitie
    gbmitie
    Apr 25, 2001
    1,117
    48
    republic of ireland now
    +56
    just think the signal will come from a satelite so the proper sat cable will be used from lnb to hd box. its when it goes from sat box to tv that good or special cables will be required.
    gbmitey
  3. loadsofleads
    loadsofleads
    Hi leedsfireman, the specification of the coaxial will remain the same. A good quality cable such as CT100 with a good foil screen, preferably copper, will do the trick. If you want to go OTT, CT125 should suffice :thumbsup:
