R
RyefordPaul
Does anyone know if you can have a Sky HD box and a Sky+ box in the same room? In other words if I switch on one with the remote, select a channel, will it also switch the other box on & put it on the same channel?
At the moment I have a Sky+ 160gb box with an old style Sky Digital box in the same room, & the two work happily together as the two remotes must be on different frequncies.
I would like to have the answer so that I can decide if I go for Sky HD or stick with what I have.
