Sky HD Box Phone Cable PITA
Discussion in 'Sky Digital TV Forum' started by Flugzeugler, Feb 13, 2009.
  1. Flugzeugler
    Flugzeugler
    Oct 6, 2005
    828
    Leeds
    +38
    Stuffing the cable down the edge of the carpet is proving more difficult than I thought. Surely, these days, there should be a wireless solution?:confused:
    How long would I get away with leaving the box disconnected from the phone socket? (Just installed today)
    Edit: Anyone know if this would work?
    http://www.amazon.co.uk/One-All-SV1550-Wireless-Extender/dp/B000MRZM4U
  2. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    I don't know what the difference is but the Amazon description ends with:
    Please note the SV1550 is not suitable for sky+ or Sky HD box's, but will work for sky box
  3. SHATNERSTACTIC
    SHATNERSTACTIC
    Sep 9, 2007
    3,413
    2
    2
    +590
    I have this unit to connect my multiroom box to the phone line. I also tested on my main box and both had the 'Telephone Line Connected' on system test with this. So, for me, it worked fine with a Pace Sky+ and a Thomson Sky HD.
    Worth noting that these do not conflict with 200mbps homeplugs, something that is not documented anywhere else...:thumbsup:
  4. chilipepper195
    chilipepper195
    Jun 11, 2005
    113
    +8
    I had Sky HD installed early September with multi room and unplugged it (well the installer told me that I didn't need it all the time and took it out himself and put it in the box for future use) and haven't had any warnings/been charged double yet although I'm sure its only a matter of time. If I do get a warning, I'll just plug it in temporarily.
  5. shop-bright
    shop-bright
    Jan 4, 2009
    11
    London
    For me its not the phone line its all the bloody power cables as they are thick, the phone line is thin.
  6. wellfan
    wellfan
    Jan 1, 2007
    320
    28
    Lanark
    +27
    Ditto. Disconnected since September. Multiroom working fine and **** them if they give me any grief. I am just looking for an excuse to cancel.
  7. Flugzeugler
    Flugzeugler
    Oct 6, 2005
    828
    Leeds
    +38
  8. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    well unless you have multiroom there is no need for the phone connection.
    And even if you do have multiroom then sky may not hassle you to connect, as folk report here (including me)
