Sky HD Box output to multiple analogue tv's
Discussion in 'Sky Digital TV Forum' started by meansizzler, Jul 12, 2015.
  1. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    I have a situation where need to output single from sky hd box to 20 screens, (gym equipment with analogue tv tuner screen). Do not require IR channel switch
    I am told that there is a multiswitch with many IF outputs, one sky box is already connected to it.
    I was thinking of something along the lines of this would work, i.e 3 x setups of the below
    IF Out from Multiswitch - Sky Box HD - SKy IO Link - Digilink RF 8 Way Amp - Each TV
    Digilink AMP Located next to Sky Box, run from Amp to each screen it max 20M.
    Would the setup mentioned work and would I face an issues?
    Digilink AMP
    Labgear Mains Powered DigiLink Amplifier 2 Inputs 8 Outputs with IR Return | Distribution Amplifiers | Screwfix.com
    IO Link
    Sky iO-Link for SkyHD | Maplin
  2. logiciel
    logiciel
    Feb 2, 2008
    53,163
    UK
    +5,789
    It's not what would normally be called a Multiswitch but it is the right sort of thing.
  3. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Yes it is more of a Mulit output UHF Amplifier, A multiswitch is already present I assume in loft space.
  4. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,991
    +1,176
    The Triax io link is considered the best built and most reliable. I'm not sure what Labgears reputation is it but it may be better to look elsewhere than a DIY store...
    Use decent wf100 cabling and you should have no issues, unless the gym equipment creates interference! Unlikely, hopefully...
    If it's for subscription channels you'll need the appropriate Sky Business sub for public broadcast.
  5. TJT1
    TJT1
    Jul 29, 2011
    4,831
    East Sussex, UK
    +1,141
    Someone posting here recently had just that problem with a treadmill.
  6. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,991
    +1,176
    Wasn't that a TV? You'd hope gym equipment with built in screens would be adequately shielded.
