Chestylaroo
Joined
Jun 6, 2021
Messages
2
Reaction score
Points
Age
42
Location
Leicester
Hi all,
I’ve cancelled my skyq subscription and need to send my box back, I have plugged in my old sky+hd box with old card and getting the dreaded no signal message.
I have already
Reset the box
Downloaded new software
Reset LNB
Cables are fine
any help would be appreciated - signal saying not locked. The signal is perfectly fine on my skyq and receives all the free channels ?
thanks
You let $ky fit a Q lnb when they did the install. They don't work with the old $ky HD boxes (and they only work as receivers with the correct LNB type anyway).
Change LNB for a hybrid or legacy quad lnb. (Many threads here on how to do that).
Consider a new freesat 4k PVR as they are compatible with the Q LNBs.
Is Home Theater DEAD in 2024?
Back
