Moldiver
I've finally been switched to unlimited sky broadband instead of connect after years and now I want to try sky anytime+, problem is, phone socket is downstairs and I've got a cable that runs from the master socket to a socket in the tv room which has only one point for the small net connection that comes from the router.
An adapter is no use as I can't have sky and net going into the same socket because it sends different signals which make my net unusable.
I've thought about plugging the sky box directly into the router but the small cable that comes out the back of the box is the same one the router uses for net and the sky routers only have one connection for this.
Any help would be great, thanks.
