Sky HD Box, Fone Line not Working
Discussion in 'Sky Digital TV Forum' started by hybridtheory, Jan 11, 2012.
  1. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    Antrim, Northern Ireland
    +388
    When I try to use the Sky Interactive Services through my 1TB Sky HD Box I receive Error Code 105 along with a message saying:
    There was a problem with your online connection. Please check that your viewing card is inserted, and your set top box is connected to a telephone line that is not in use. If the problem persists....
    To check my line to the Sky HD box I connected it to a BT fone and it works fine, I can make/receive calls so why won't it work when its connected to my Sky HD box.
    On the EPG, if I go into Settings>Signal then go to Page 2/2 it says Telephone Line Not Connected.
    It all seemed to happen around the same time that I got BT Infinity installed. Anyone any ideas?
    Baz
  2. HD sceptic
    HD sceptic
    Apr 1, 2009
    814
    28
    Glasgow
    +81
    Is the telephone cable between the sky box and the phone line damaged?
  3. hutchri
    hutchri
    Dec 20, 2011
    33
    11
    Nottingham
    +5
    Have you ensured that you have placed micro filters on all of your phone devices (including the Sky box connection)
  4. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    +388
    No, as I said if I connect a fone to the rj 11 that goes into the back of the Sky HD box, the done works fine.
    Baz
  5. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    +388
    Since having BT Infinity installed I no longer need micro filters.
    Baz
  6. logiciel
    logiciel
    Feb 2, 2008
    53,066
    UK
    +5,740
    It makes a change to have a poster who actually wants the phone connection.;)
  7. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    Then its probably the RJ11 modem connection in the Sky box itself which is damaged.
  8. SevloW
    SevloW
    Aug 13, 2008
    3,112
    5
    Area 51
    +1,170
    Just check that the phone line is plugged into the RJ11 on the back of the Sky box rather than the RJ45 for the Ethernet connection .
  9. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    +388
    This issue is really starting to bug me. I took my Sky HB 1TB box into another room that has Sky, connected it all up and guess what, yup the line connects fine so the modem in the box isn't faulty. Yet when I plug move the box back into my room the fone line fails. The fone line works when connected to a fone, just not the HD box even though the modem isn't faulty. Anyone any ideas, Im at a loss.
    In a previous post, it all worked fine before BT Infinity was installed.
    Baz
  10. Fishnose
    Fishnose
    Nov 4, 2011
    5
    I have had same problem. Check that you havn`t put the phone line into the ethernet socket as i had. just a thought.
  11. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    +388
    The fone line is 100% in the correct socket. Just seems very odd that it's not worked properly since BT Infinity was installed.
    Baz
  12. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    At the risk of being censored by the "spelling police", every single response has spelt "phone" correctly.
  13. Fishnose
    Fishnose
    Nov 4, 2011
    5
    I know the filters are not supposedly needed for BT Infinity but the line on mine was ok after fitting one. The line did not work without one even after using correct socket on the Sky receiver.
  14. hutchri
    hutchri
    Dec 20, 2011
    33
    11
    Nottingham
    +5
    I know it does sound strange, but its still worth trying the phone line via a micro filter - as various forums appear to report strange behaviour without, despite fibre broadband.
  15. hybridtheory
    hybridtheory
    Mar 31, 2009
    6,247
    +388
    Well, well, well, what do u know.... The micro filter done the trick. Thanks very much :thumbsup:.
    Just seems odd how the fone line worked fine without the micro filter but the Sky Hd box didn't :confused:.
    Whats even more odd is, the other Sky HD box about a metre away from the BT socket worked fine without the micro filter :confused:.
    Baz
  16. hutchri
    hutchri
    Dec 20, 2011
    33
    11
    Nottingham
    +5
    It appears to be the Sky boxes are manufactured on the belief that most customers will also use Sky broadband with them, so they almost expect a micro filter. Still very strange behaviour you experienced though.
  17. Fishnose
    Fishnose
    Nov 4, 2011
    5
    Pleased that this issue is now resolved. i was on the verge of calling BT, which would of cost £130 even if it was their misinformation concerning the micro filters. Saved cash will go towards a Sky HD 1TB receiver very soon. Thanks to all for keeping my sanity intact.
  18. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Fibre broadband, in the UK, for the most part is only to the cabinet in the street, the final delivery to the home is still via the copper telephone cable - hence the need for filters.
