Sky Hd And Existing Compatiable Tv's
Discussion in 'Sky Digital TV Forum' started by potshot, Sep 2, 2005.
  1. potshot
    potshot
    Jan 31, 2004
    2,039
    63
    +181
    Hi does anybody know what existing tv's will work high def from sky. I have a toshiba picture frame picture frame 2 tv and I think it will take the 700p output from sky HD via component output.
    Does anybody know which existing TV's will accept the 700p spec.
    I am sure there are plenty of members who will want to know the answer, saves buying a new TV.
    pot
  2. scarty16
    scarty16
    Jul 1, 2003
    1,058
    +97
    try the Plasma, LCD forums aetc s they have long lists
  3. potshot
    potshot
    Jan 31, 2004
    2,039
    63
    +181
    I am thinking more of the crt tv's at present, some will take the 700p spec from the sky HD box.
    Which ones will.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    As far as I know only one model from JVC and Samsung can actually take HD source material (1080i only I believe) but those were built for HD, they are not PAL spec sets which can accept progressive signals from a DVD player via component.
  5. scarty16
    scarty16
    Jul 1, 2003
    1,058
    +97
    720p at 50hz and 1080i at 50hz
    is what you need thrugh HDMI/DVI (HDCP) or analogue to get HD
  6. potshot
    potshot
    Jan 31, 2004
    2,039
    63
    +181
    The box will come out with a component out for 720p and 1080i as well as hdmi/dvi, my toshiba picture frame tv is progressive scan that is the component in and I am sure it can handle the 700 lines because of the progressive scan.
    I wouldn't buy one the new HD plasma's thats out at the mo, they are well over priced and by next year they will be half the price.
    Just out its not compatiable so will buy a new plasma next year. What are the best HD ones out.
  7. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    What is the model?
    I expect the CRT takes PAL progressive (576p) and as it is based on a 625line tube is not capable of accepting or displaying a 1280*720p signal.
    The SKY+ HD may be able to supply a 576p feed via component but considering what the STB will cost it's alot of money for a little return.
  8. potshot
    potshot
    Jan 31, 2004
    2,039
    63
    +181
    Found out its not compatiable.
