Sky HD and A pioneer 503MXE
Discussion in 'Sky Digital TV Forum' started by miniman, Mar 27, 2006.
  1. miniman
    miniman
    Apr 14, 2003
    568
    Birmingham
    +7
    Just a quick one but will my 503 mxe work with sky hd I also have a iscan ultra. Any help before the deadline for free fitting of sky hd ends would be grateful. Mark
  2. miniman
    miniman
    Apr 14, 2003
    568
    Birmingham
    +7
    I have done a search but cannot find any info
  3. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    I think it should be OK with 1080i50 via component - not too sure about 720p50 though. I'm hoping my MXE will be, at least!
    Steve
  4. miniman
    miniman
    Apr 14, 2003
    568
    Birmingham
    +7
    Thanks for taking the time to reply Dutch. I think I will go for it, if it doesn't work I will have to get a iscan HD. Thanks again for the help and good luck with yours. Mark
  5. klnc
    klnc
    Oct 2, 2002
    385
    London
    +36
    Jumping in, but Dutch, which output do you use for your lumagen to get native on your mxe - DVI or analogue RGBHV? Understood DVI was best at 70hz, albeit with some judder, or 75hz on Input1/2.
