Sky HD and 5.1 sound dropout via optical - help please before purchase of amp...
Discussion in 'Sky Digital TV Forum' started by pedwards13, Jan 23, 2008.
  1. pedwards13
    pedwards13
    Hi all, newbie here and about to make first delve into home cinema...
    Have been researching these forums, and have seen plenty of mentions of the 5.1 signal from Sky HD dropping out on various amps
    Can anyone confirm for me if there any problems with the Onkyo 605 and Sky HD? Will be connecting SKy HD > TV with HDMI and Sky HD > Onkyo 605 via optical
    Thanks in advance,
    Paul
  2. mitchec1
    mitchec1
    Jul 20, 2006
    3,825
    Birchington
    +2,082
    Onkyo 605 will be fine for 5.1 from Sky HD via optical, none of the Onkyo's have any major issues with Sky HD
  3. Dodger3
    Dodger3
    Dec 21, 2007
    59
    +11
    Is this only a problem with some amps and not others?
  4. pedwards13
    pedwards13
    thanks for your help - hopefully it will be OK!
  5. smjxm09
    smjxm09
    May 27, 2006
    1,385
    48
    +81
    It affects my Sony Amp but with the fault recorded on the hard drive I can't see how it is an amp issue
  6. Ultra2man
    Ultra2man
    Dec 19, 2003
    1,140
    2
    Biggleswade, Bedfordshire
    +260
    The audio drop outs are a Sky transmission problem and nothing to do with the amp.
    As said in the last post if it is recorded onto the hard drive there is nothing you can do about it.
    You can as often watch a movie with no drop outs as have one that drops out frequently.
    This is one of the biggest bugs with Sky and is not restricted to the HD box. I used to get exactly the same with my old Pace Sky+ box.
  7. 961
    961
    Oct 13, 2006
    4,675
    Berwickshire
    +667
    As said elsewhere this is a transmission problem and can be found regardless of the hardware and cabling within your installation
    You eventually learn to live with it:suicide:
