Sky HD - 480p/60
Discussion in 'Sky Digital TV Forum' started by chedmaster, Mar 22, 2006.
  1. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    Is there any chance the Sky HD box will output 480p/60? I know its a long shot but worth a try :)
  2. mark800
    mark800
    Feb 16, 2006
    4,351
    167
    Huntingdon
    +2,240
    Nope - all in 50Hz I'm afraid at 576p, 720p or 1080i.
  3. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +6
    I thought 576i was on the cards too?
  4. ollie501
    ollie501
    Jul 14, 2003
    1,007
    Dorset, UK
    +25
    Can you clarify what 480p/60 is like by comparison to the other formats? I'm still very new to all this hi-def lark.
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    Its fantastic. I would call it twice as good as SD, closer to "true" HD (i.e. 720p/1080i) than it is to standard SD.
    This is based on HD demoes, run from Media Center to Xbox 360, which then downscales to 480p/60 and outputs via component.
    I haven't seen 576p/50 native (only on 480p plasma), but I imagine the Toshiba xxZP38/48s will outperform most 768p LCDs in SKY HD land.
  6. mark800
    mark800
    Feb 16, 2006
    4,351
    167
    Huntingdon
    +2,240
    Sorry, I meant to type 576i - my mistake! :(
  7. mark800
    mark800
    Feb 16, 2006
    4,351
    167
    Huntingdon
    +2,240
    480 line resolution is what you get from US DVDs. The resolution is not as good as you will get from PAL DVDs (576 lines).
  8. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    480p is mostly SD, which is so old looking on my HDTV lol.
  9. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    Thats a nice constructive post :boring:
    480p is not SD, it is classed as ED (enhanced def.) mainly, and HD by the Xbox 360.
    Also DVDs are in SD interlaced format (although some clever and expensive scalers can recreate progressive frames from it). That means they are 576i or 480i, very different to true (/downscaled) 480p/576p.
  10. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Is that a 576 line LCD then?
  11. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    I,m just glad i can run 1080i on my TV.
  12. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    What TV is that then?
  13. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    No, a progressive scan CRT.
  14. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Oh I see, then I fully expect it (and the Panasonic) will massively outperform any LCDs although 720p might spice things up a bit
