sky+HD 1tb no input 2 info
Discussion in 'Sky Digital TV Forum' started by callum181, Aug 6, 2013.
  1. callum181
    callum181
    Aug 6, 2013
    3
    OK so i have just bought a second hand box of someone got home installed it paired the card to box on-line etc etc.
    I have all channels they work. However when i try to record ONE program and watch another i get a clash. Please note this is defo the case.
    So when i go into menu and goto settings then signal it just shows details for input one the are no mention of input 2. so i assume this is the issue.
    Iv tried a system reset iv swapped the sat cabling over at the back each time only giving me input 1 details in the signal menu.
    I dont have single feed turned on if this is even todo with this. anyone seen this problem before??
    thanks callum
  2. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Actually, I think you have. Please set it to ON, store the setting, reboot, set it to OFF, store the setting, reboot if necessary, report back.
