Sky+ Hard Drive
Discussion in 'Sky Digital TV Forum' started by Rock Da Bass, Jul 8, 2002.
  1. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,786
    EU
    +816
    Hi all,
    Thinking of getting Sky+ but one thing bothers me.........
    Is the hard drive on Sky+ subject to fragmentation in the same way that the hard drive on a PC is? In other words, after a bit of use do bits of recordings end up all over the disk and affect the machine's performance? If so, is there a defragmentation function (ideally the machine will maintain itself 'on the fly')
    Thanks in advance,
    RDB :)
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,160
    Warwick
    +3,006
    One of the "discoveries" made by people who had experimented taking out the HD and installing a larger one is Sky+ formats the disk section it is writing to just before it writes to it. This would mean fragmention does not become an issue.
    I could be wrong on this - I don't have that much technical knowledge of how hard drives work - but this is how the situation has been explained to me.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    If push came to shove you could use the "Housekeeping" function on SKY+ which wipes the disc, you will lose all the recordings and series link information stored.
    Sounds like reformat to me but not in the same sense as a total PC hard drive reformat I think.
  4. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,786
    EU
    +816
    Thanks for the replies. Either way sounds okay. If the disk needs to be 're-formatted' every now and again it's not that big a deal.
    Cheers,
    RDB :)
