Sky+ Hard drive
Discussion in 'Sky Digital TV Forum' started by graham w, Mar 30, 2005.
  1. graham w
    graham w
    been reading up on an upgrade on a sky+ v2 pace and seems quite straight forward, my question is, does it seem feasable to remove the old hard drive
    connect it to a pc with removable bay.Transfer the files over to drive c,remove the drive and fit the new drive to the pc,put the files over to the new hd and then fit it back in the pace?
    Just to keep my current recordings.
  2. MikeNolan
    MikeNolan
    Nov 28, 2004
    540
    Hereford
    My sky+ box has locked into standby mode so it will need replacing - luckily it's under warranty - unlucky, lost a lot of unwatched programs. Need to think about buying a DVD recorder, as there are many messages on this forum about Sky+ boxes falling over!!
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Feasible ? Yes. But I haven't heard of anyone that has successfully done it.
