Sky+ Hard drive missing 25%
Discussion in 'Sky Digital TV Forum' started by potshot, Nov 8, 2004.
  1. potshot
    potshot
    Jan 31, 2004
    2,058
    63
    +184
    My sky+ box is saying I have 32% free space which means I am using 68% of the space. Adding up the used space comes only to 43% used which means I have I should have 57% free space. Because of this it wouldn't record two programmes because there wasn't enough disk space.
    How can I resolve the problem, does anybody know the engineer codes to reset all the software.
    My only other option is to put another maxtor hard in.
    The system is rubbish. Even though my box has just gone out of warranty sky+ is still responsible because products need to be durable and fit for the purpose they where sold for. I have dealt with bigger fish than sky and won.
    Mike
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    The go to court again, others have and won:)
    Now for a fix, do a Planner Rebuild, that should clean up the hard drive indexing an recover the "missing" capacity without the need to wipe the hard drive.
    On the remote...
    Services
    4
    Select
    Then choose option 7.
  3. potshot
    potshot
    Jan 31, 2004
    2,058
    63
    +184
    Thanks alot starburst.
    Mike
  4. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    Hope I'm not being too thick here, but it should be clear to type in 401 while in the Services menu....I tried looking for the options 4, 0 and 1! Doh!
    It didn't work anyway. I'll try deleting all that is stored and rebuild it again.
  5. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Just press the keys, don't look at the screen it'll confuse you.
  6. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    :laugh: It just might, it's big enough :thumbsup:
  7. lmccauley
    lmccauley
    Oct 24, 2000
    3,535
    Newcastle
    +327
    I had exactly the same issue and did a Planner Rebuild. Now my Sky+ box won't switch on. Help!
    I've tried unplugging it for 5 minutes & plugging it back in, but nothing. Won't respond to remote, or on/off button on facia.
    Any suggestions?
    Cheers,
    Liam
  8. lmccauley
    lmccauley
    Oct 24, 2000
    3,535
    Newcastle
    +327
    Panic over (well, for me, anyway). Left it switched off overnight & it was fine this morning. Only problem is it still says I've only 60% free, when I don't have anything else recorded. Time for a full system reset, I think.
    Cheers,
    Liam
  9. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,045
    Am i being thick here but i can't find the Planner Rebuild. I press services, press 4 and then there isn't a 0 option. Am I doing something wrong?? :confused:
  10. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    As bobcar says a few posts above.........
    "Just press the keys, don't look at the screen it'll confuse you."
    The menu is hidden until the final key press:)
  11. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,045
    Ah, right, I was being thick, I'll try this tonight...Thanks Starburst...
  12. brendonw
    brendonw
    Nov 16, 2001
    582
    Bristol
    +59
    Worked for me too!
    Many thanks
  13. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's Services, 4, 0, 1, Select
    People forget the Select and it doesn't work.
