Sky+ hard disk upgrade?
Discussion in 'Sky Digital TV Forum' started by Wally, Dec 30, 2003.
  1. Wally
    Wally
    Has anyone opened their Sky+ box and worked out if it is possible to replace the standard 20Mb disk with a bigger unit? I wonder if a software/firmware upgrade would be needed to access the additional disk space or would it just detect the new disk as in a PC?
    I guess opening the box invalidates the 1 year warranty too?
    All responses appreciated!
  2. gbmitie
    gbmitie
    Apr 25, 2001
    1,117
    48
    republic of ireland now
    +56
  3. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    It was covered in HCC recently.
    pdf file available here
  4. NicolasB
    NicolasB
    Oct 3, 2002
    5,890
    Emily's Shop
    +569
    The standard disk is 40MB.
  5. gbmitie
    gbmitie
    Apr 25, 2001
    1,117
    48
    +56
    I think people get confused with the 20 hours recording time and the 40mb disc ie say 20mb when meaning 20 hours and vice versa.
    gb--
  6. hmsq
    hmsq
    Nov 3, 2003
    683
    London
    +42
    sorry but it is 40GB not MB!:D
  7. gbmitie
    gbmitie
    Apr 25, 2001
    1,117
    48
    +56
    just testing
    hny
  8. Wally
    Wally
    Thanks to all on this subject. I stand corrected on the default disk size (40Gb) and look forward to replacing this with a 120Gb unit. I'll post the outcome of this upgrade to add to the existing knowledge and experience.
  9. Fernsehman
    Fernsehman
    It's been covered on the "hummer" site (I forget the URL) and in the satcure technical section and in "What Satellite TV" magazine a couple of months ago.
  10. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    Very hard to prove you have been in the box as Sky have not put any warranty seals on the box at all :clap: :smashin:
    So as long as you keep your old drive you shouldnt have any problems:smashin:
  11. gbmitie
    gbmitie
    Apr 25, 2001
    1,117
    48
    +56
    I thought the srews on the side wre not your normal and not that easy to undo without messing them so that it would be obivious they were tampered with?
    gb--
  12. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,578
    48
    Lancashire
    +49
    Screws are a security Torx (pin in the middle), bits easily available - Maplins, Screwfix to name but Two suppliers. I've just done mine, go for it it's easy. I can recommend Samsung drives.
  13. gbmitie
    gbmitie
    Apr 25, 2001
    1,117
    48
    +56
    thank u.
    gb--
