SKy+ hand set buggered, any help?
Discussion in 'Sky Digital TV Forum' started by (GTV)Chris, Dec 22, 2004.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    My handset was droppen and now it dont work....
    Any suggestions..can i get a new one ...can i get one from a cheap source?
    Like an all in one?
    Chris
  2. thfccambs
    thfccambs
    Jul 17, 2002
    19,095
    White Hart Lane
    +5,168
    Call sky tell them it faulty,i did and they sent me one free.
  3. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    One thing to try is leave the batterries out of the remote for a couple of hours and then put them back in and try again. This can sometimes fix them.
    I bought a second remote from here http://www.letsautomate.com/10772.c...=5c14933-df95687b-947e-4599-8420-307c8f14ea7c it was almost £10 cheaper than from Sky by the time postage is taken into account and it arrived next day (not at this time of year though).
  4. Henry
    Henry
    Aug 9, 2000
    2,162
    Hull
    +52
    That's a bargain. I paid nearly £30 for mine. You can get them from Argos if you're in a rush and need one asap.
  5. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    Thanks guys.
    I have ordered one...but I may also check Argos....After all, It's Xmas and no remote means a grumpy Chris and wife :(
    Ta
    Chris
  6. pezzer
    pezzer
    Jun 9, 2004
    185
    West Sussex
  7. dsk19s
    dsk19s
    home base do remote and tv link for £20 bargin :)
