Sky freesat missing channels
Discussion in 'Sky Digital TV Forum' started by elmec, Aug 11, 2005.
  1. elmec
    elmec
    Can anyone help i have a pace minibox 1000, ive registerd to freesat from sky, on selecting channels it misses itv1, chan 4, chan 5, jumps from beeb 2 to sky1, when i go into services and add channels i can find itv1 but it wont come up on the main menu, any ideas
    Jason
  2. DaveP
    DaveP
    Have you called Sky to get the card activated?
  3. elmec
    elmec
    Hi yes called sky and card is activated, any more help please
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Go to Services >> System Details
    Does the Sky card number show up ? If it doesn't, try pulling the card in and out a few times to clean the contacts.
    Failing that, try a forced software update..... power off, press and hold in the backup button on the front of the box whilst powering up. Keep button pressed until you see the on-screen display.
  5. griffo
    griffo
    I've just had sky+ installed today and had the same problem with the same channels. I phoned sky and was talked through a procedure that upgraded the system software in the box. The procedure is probably different for the pace box (but Nick UK's post suggests that it would be the same).
