sky free to view/air cards
Discussion in 'Sky Digital TV Forum' started by pea69, Feb 7, 2009.
  1. pea69
    pea69
    i have linked up my old sky box upstairs to the satellite dish to try and watch the free to view channels in the bedroom- as easier than getting new didgital aerial-
    do i need a viewing sky card? if so how can i get one without going through ebay- as they may not work after a while...??
  2. GasDad
    GasDad
    Remembered (1964-2012)
    Mar 28, 2006
    5,407
    Bristol
    +758
    From sky - 20 quid, Guaranteed to work for 3 years.
  3. jlearmonth
    jlearmonth
    May 5, 2008
    612
    +19
  4. Prime Time
    Prime Time
    Nov 4, 2007
    119
    Glasgow
    +12
    You will miss out on your correct ITV Region, Channel 4 and Channel 5 on the EPG without the viewing card. However, the FTA versions of Channel 4 and Channel 5 can both be added using the other channels option on a Sky box.
    Access services
    System setup
    Add other channels option.
    CHANNEL 4 - 10.714 H 22 FEC 5/6.
    CHANNEL 5 - 10.773 H 22 FEC 5/6
    Without the card you will not get Fiver of FiveUS which are FTV.
    As said you can get the card from Sky by phoning 08448 244 400 for less than £20.
    With a viewing card you will also be able to order a Setanta satellite subscription.
