Sky feed (RF2 out) into a set-top box ?
Discussion in 'General TV Discussions Forum' started by mccormickhome, Dec 30, 2004.
  1. mccormickhome
    mccormickhome
    I'm running a Mustek set-top box and get the 30 freeview channels, but i cannot seem to receive the sky feed from the sky box downstairs (RF2 out) on the coax lead (which is on channel 847.25Mhz according to a portable TV).....am I mising something and why doesn't the set-top box see the sky feed ????
    cheers
    Paul
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    STB has digital tuner only and sky RF2 output is analogue.YOur STB may or may not passthrough analogue (should) so you would need to use TV internal tuner to access the Sky output
  3. mccormickhome
    mccormickhome
    Cheers for the fast response amazing.........as I thought the RF2 out is analogue....is there anyway I can get a feed through the STB Mustek DVB-T202 to my projector ?? Have you heard of any con
    converters ?
