Sky + fan runs all the time
Discussion in 'Sky Digital TV Forum' started by paiger, Jul 1, 2003.
  1. paiger
    paiger
    I have just bought a second hand Pace 3100 and the fan runs all the time. I don't need the PVR functions, just 5.1 audio so I pulled the HDD out of it (added benefit of stopping the silly lights on the front. The box works OK but the fan starts from cold and it's reasonably noisy. There is no way the box is too hot as I have just put it back in the rack.
    Does anyone know where the heat sensor is? Do I need the fan if no hard drive is fitted?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Perhaps the previous owner wired the fan to run all the time, maybe upgraded the HD of it was in a poorly ventilated area.
    Never opened mine so can't say what goes where but without a HD (Main source of heat) a fan is totally pointless so just disconnect it.
  3. paiger
    paiger
    The HDD was a 40gb Maxtor. It was red hot when I opened the box after about 3 hours of running! I reckon this was a faulty box that somehow got shifted out into the market as they couldn't get the fan to stop! Got it cheap anyway so not fussed, in fact made £70 profit from selling my Sony box!
    I disconnected the fan and it seems fine, gets less hot than the Sony as it's better vented and a bigger case. I will have to accept that I will never be able to use it as a full Sky+ box without constant noise but I only wanted it to get 5.1 from Premier.
    Mission accomplished, a free 40Gb HDD and a few quid for a curry and a San Miguel (or 11).
