Sky + fan noise
Discussion in 'Sky Digital TV Forum' started by sacd, May 16, 2004.
  1. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    OK, so I love sky +, but when I first had it there was hardly any fan activity, now it just seems to switch the fan on and off for no apparant reason. The box may be switched off, with nothing recording and suddenly the fan would go on. Reasons anyone?
  2. Ridcully
    Ridcully
    Feb 16, 2002
    356
    28
    +35
    A software drop, probably 2 months ago now, changed the way the fan works. The fan is programmed to be on a lot more. Guess Sky were getting to many failures due to over heating. Remember that even though it looks like its in standby the box is still on and possbily recording, hence heat genretion, hence fan
  3. B Caine
    B Caine
    Jul 15, 2000
    80
    Barrow North UK
    +3
    I had fan noise and bought a 12v, 50mm case fan from Maplins, I took the cover off the back of the Sky+ box, the one for upgrades, then blue tacked it over the hole blowing inwards, I run it at 6v and it`s not loud at all, you cannot hear it, a piece of muslin over the fan stops dust getting in. Now the Sky+ fan hardly ever come on and the box is cold, oh I use a power supply that can be bought at Maplins and leave it running all the time. I works great.
  4. IanW
    IanW
    Feb 28, 2001
    1,618
    Wiltshire
    +152
    Have to say mine is really noisey these days. However, when watching on the PJ and sound system it cannot be heard. :devil: :eek: :thumbsup:
  5. Stellavision
    Stellavision
    Apr 7, 2003
    2,379
    Southsea, UK
    +101
    Bought my Sky + box about a month ago.
    The fan seems to be on all the time, even when in standby which I couldn't understand. You can only just hear it when everything is quiet and it doean't really bother me.
  6. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Even in standby the SKY+ is using virtually the same amount of power and thus generating the same internal heat levels also the hard drive spins continuously which is another major heat source.
    It maybe the SKY+ just needs a reboot.
    After a new install some people have reported the fan running all the time (in a kind of default mode) and a reboot has reset the fan to normal operation (only coming on when needed).
  7. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    And how do you re boot? Do you lose all the stuff on the hard drive?
  8. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Turn it off at the plug, count to 10 then turn it back on.
    Just a power reset really not a OS reload and nothing should be affected on the hard drive or series links ets although if you were being very cautious you might make sure the HD is not recording when you cut the power.
  9. philipb
    philipb
    Mar 6, 2002
    2,034
    63
    Swindon
    +149
    Reboot didn't work for me - the fan is on continuously even in standby.
  10. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Then it's safe to assume that the SKY+ is simply running too hot and the passive ventilation is too low and needs the additional airflow generated by the fan. That would be very worrying as it would indicate the temp never reaches "safe" levels and therefore the lifespan of the internal components is likely to be reduced.
    It could be a hardware fault of course but it might be useful to move the SKY+ into a well ventilated area (or even remove the case) and see if the fan turns off.
  11. cerij101
    cerij101
    Oct 14, 2007
    7
    My fan (Thomson) sounds like a 737 on takeoff. I wonder if a squirt of WD40 would help...
  12. Stellavision
    Stellavision
    Apr 7, 2003
    2,379
    Southsea, UK
    +101
    i doubt it!:nono:
  13. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    Dust will stick to it and make the problem worse. Try cleaning the fan.
