Sky+ failed recordings
Discussion in 'Sky Digital TV Forum' started by coggs, Jun 30, 2005.
  1. coggs
    coggs
    Apr 2, 2005
    81
    +5
    I seem to be getting lots of 'Failed' recordings on sky+.
    I have called 'sky' a couple of times, but they say it's down to a software problem and have no idea when it will be updated.
    Does anyone else get this fault. Is their a software problem or are they fobbing me off. I have an amstrad box about 6 months old and it happens about 3 times a week.
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    Can't way I've heard of it being a software problem I've had around 3 failed recordings in over 2 years of Sky+ ownership.
    You might want to try a planner rebuild - although this will delete ALL recordings.
    Press:
    Services
    4
    Select
    and then choose option 7.
    HTH
    John
  3. coggs
    coggs
    Apr 2, 2005
    81
    +5
    I've not tried that, I've done the housekeeping one a couple of times, but with no joy. I just got a few recordings I don't want to loose, but if this continues I might have to go with the rebuild.
  4. HMHB
    HMHB
    Nov 11, 2001
    25,560
    Nottinghamshire
    +3,892
    The only time I've ever had failed recording is when I've done something silly myself like trying to record 2 programs at the same time as watching a 2rd channel, other than that I've not had any failures. Are your signal strengths OK ? Which Sky+ box do you have ?
  5. coggs
    coggs
    Apr 2, 2005
    81
    +5
    It's an amstrad. Yep signal strengths seem fine.
