SKY+ Failed Recordings
Discussion in 'Sky Digital TV Forum' started by WarPig843, Dec 28, 2004.
  1. WarPig843
    WarPig843
    Oct 21, 2004
    304
    +19
    Recntly got Sky+ and Im getting a few random 'failed recordings'.
    No info given on screen for reason why.
    Any solutions before I retun the box?
  2. dts borg
    dts borg
    Sep 5, 2001
    577
    Hornchurch
    +8
    Don't return it :nono: Because you will end up with a second hand recon :suicide: Call Sky + they will tell you how to reboot your box :rolleyes:
    Good luck ;)
  3. MrBurns
    MrBurns
    I have had this problem a few times. The last time was due to bad weather. The gutter outside my house leaked onto the satelite dish and messed up the signal so the program stopped recording.
    Take a look at where your sky satelite is located, because rain falling directly on the dish can affect it.
    Also make sure there is enough space on your sky box, because programs will stop recording if you run out of space. And finally make sure that your leave the sky box turned on while you are attempting to record a program, leaving the sky box on stand by is fine.
    If you still have problems then you probably have faulty sky equipment.
    Hope this helps. :smoke:
