(Sky +) Failed recording
Discussion in 'Sky Digital TV Forum' started by THFC, Jul 13, 2004.
  1. THFC
    THFC
    Feb 24, 2003
    242
    Gloucester
    +5
    How often does this happen to others on here.
    For some reason the recording fails and will only delete not play. It happens quite frequently i find -
    :mad: annoying - recorded waking the dead BBc1 sunday - ok
    recorded the 2nd part monday night on bbc1.
    was watching top gear off the hard drive at this time when sky+ switches off on it's own.
    waking the dead now appears as a failed recording
    Sky + is excellent it's just these glitches, mostly on the BBc that pi** me off
    Surely Sky may look into this if enough expeience these failed recordings
  2. HMHB
    HMHB
    Nov 11, 2001
    26,716
    Nottinghamshire
    +5,482
    Touch wood I've not had any problems so far with failed recordings (apart from series links not working due to EPG not being correct). I don't record much off the BBC to be honest, so I wonder if it's just a problem with that ? I do record Top Gear every time it's on BBC2 and they've all been OK. I have the Amstrad Sky+ box.
  3. MonkeyBoy
    MonkeyBoy
    Aug 4, 2000
    115
    Didcot
    +10
    If you look at the program size bar at the top, you will probably find that the programs that are failed do not show as using any space on the drive.
    If this is the case it means that the recordings are corrupted and you will not be able to recover them.
    The best thing to do to try and stop it happening again is to do a software update (This may lose your recording, but probably not) and if this does not work you should do a full system reset (This WILL wipe all you recordings and series links).
    Hope this helps
    Steve
  4. BigRD
    BigRD
    Jul 4, 2003
    393
    far far away
    +14
    This is a known problem with Sky+ and the BBC. Apparently the problem lies with the BBC and there's a blurb about it on their website. I have read it but can't remember all the comments etc. :thumbsdow
