Sky Eye
Discussion in 'Sky Digital TV Forum' started by Rookies, Oct 24, 2005.
  1. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    You know with Sky eye can you only have it at certain length for the remote to respond?
  2. JayCee
    JayCee
    Jan 20, 2004
    24,147
    Lanarkshire
    +2,651
    You need to give more info if you want an answer.:lesson:
    Are you talking about the cable distance from the Sky digibox to the tvlink?
    or
    The distance between the Sky remote and the tvlink eye?
  3. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    Sorry,
    I mean cable distance from the sky digibox to the Tvlink
  4. C11 XFF
    C11 XFF
    Oct 1, 2005
    26
    Yes, i had quite a bit of cable in the loft on the run to my 2nd tv and it would not work. I shortened the cable in the loft and it worked no problem.
  5. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    I have a cable going up from the SKY+ box in the lounge into the loft to a four way amplifier ( non powered) 4 cables run from that down to three bedrooms and one goes back down to kitchen, I never had problem with that distance except for the first few connectors I put were badly done but after that Ive had no problems.
