SKY+ Extra Storage & Adverts
Discussion in 'Sky Digital TV Forum' started by tommymuldy, Nov 19, 2003.
  1. tommymuldy
    tommymuldy
    Mar 6, 2003
    11
    London
    Hi Guys,
    I'm looking into getting Sky+, but I would like more than the 20hours of storage on offer from the system as it is provided. Have any of you fitted new hard drives to your boxes?
    Would it be better to buy a DVDR to fit to copy off the Sky+? (A bit reluctant to do this as I have just bought a new DVD player)
    One last question, does anyone know if it has an option where you can edit out adverts? (I think some PVRs do this but I'm not sure).
    Thanks in advance for your help & advice!!!!
  2. JAMBO
    JAMBO
    The hadr drive can be upgraded to increase the 20 hrs recording limit. Haven't done it myself, so possibly others can explain best way to do it and maximum recording limits.
    No way of editing out adverts on Sky+, but you can zoom through them at 30x speed, so takes about 6 secs, for 3 mins of adverts.
  3. tommymuldy
    tommymuldy
    Mar 6, 2003
    11
    London
    Nice one thanks. I suppose the advert thing isn't such a big problem really if you can zoom through like you say, just the storage space.
  4. JAMBO
    JAMBO
    Sky+ gives you the option of: Normal speed, 2x, 6x, 12x and 30x. Very simple to use. Whilst in play mode, each time you press the fast forward button moves the speed up 1 notch, on the above scale. Can also be used to catch up, if you have used the live pause. E.g. to answer the door, while the footy is on....or if you miss something while the wife is nagging !!!
  5. mjcairney
    mjcairney
    Oct 26, 2003
    6,854
    2
    4
    137
    Airdrie, Scotland
    +834
    I think it was the December issue of Home Cinema Choice magazine that gave step by step instructions on how to install a larger capacity hard drive to the Sky+ box. Must say, it looked quite simple. Best of luck.
  6. thfccambs
    thfccambs
    Jul 17, 2002
    18,770
    White Hart Lane
    +4,813
    I have just fitted a maxtor fdb drive 120 Gb from ebuyer(£85),gives me 60 hours.It's really easy to fit,have a look here www.hummer.co.uk/disc-change.htm
    Good luck.
  7. tommymuldy
    tommymuldy
    Mar 6, 2003
    11
    London
    Thanks guys for the info. I will get the box and hard drive at Christmas time and give it a go!!!! Maybe I will get my Dad to do it instead....
