Sky+ extension cable
Discussion in 'Sky Digital TV Forum' started by anticlaus105, Nov 2, 2005.
  1. anticlaus105
    anticlaus105
    Nov 11, 2004
    1,156
    63
    +181
    Anyone know where the best place is to get an extension cable for Sky+ box. Flippin sky man made the cable too short.
    Cheers.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Buy yourself some CT100 cable and the F connectors from your local decent DIY superstore, that should do the job.
    If you notice any significant signal decrease then you may have to consider replacing the whole cable.
    You can see examples of what you need at Satcure, you could order a ready made extension if you wanted:)
