Sky+ epg, bit screwy lately?
Discussion in 'Sky Digital TV Forum' started by spook, Aug 25, 2004.
  1. spook
    spook
    May 18, 2004
    157
    Anyone else noticed that Sky+ EPG is a bit on the screwy side just lately?
    if you look at the quick channel information (ie the bit at the bottom of the screen whilst actually watching the channel) the programs are most times half an hour out of sync,
    I set Sky+ to record sveral progs this morning and each recording had an extra half an hour added to the end! very odd :confused:
    when I switch channels using the quick channel guide for a split second the information is correct then quickly goes out of sync, although it doesn't happen on all channels.
    I tried the reboot with the software update routine but it's still screwy?
    cheers, Spook
    Pace v3 box btw
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    The EPG clock and now & next info are just fine, I suspect it's a problem with your own hardware/software otherwise every recording for everyone would be failing:)
    Have you got a list of the affected channels and do you know if there are any links between them, same transponder/satellite etc?
    What are the Network ID and Transport Stream indicating ?
  3. spook
    spook
    May 18, 2004
    157
    network ID= 0002
    transport stream 07d4
    signal strength and quality ok
    seems to be working ok just at the moment,
    just another thing, i noticed earlier today as i was flicking through the channels that the epg information dissapeared all together for a couple of minutes just showing the info for the current program with "progam information not available" or something like that underneath unable to scroll down to see later programming?
    odd!
    cheers, Spook
