Sky+,dvd Recorder And Camcorder Or Video
Discussion in 'Sky Digital TV Forum' started by AFCB01, Mar 29, 2005.
  1. AFCB01
    AFCB01
    Have just had sky+ installed to replace the old ntl digital box I had.
    I stupidly didnt make a note of all the scart connections.
    The way it has been set up allows me to record to DVD from the SKY+ box either from the hard drive or from the channel direct.
    Before I was able to connect a camcorder or a video recorder so that I could view that and record it onto DVD (this cut out the satellite picture)
    Sure its simple but what scart setting do I need to do this.
    Is it a case of Scart from Sky plus box into DVD recorder - scart out from DVD recorder to TV and then replacing the one into the DVD recorder with
    the Scat for the Camcorder?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Not 100% sure since cable connections are a very mysterious science which seems to have more to do with how the furniture is laid out and what is allowed to be seen:)
    Perhaps if you plugged in the VCR/Camcorder into the SKY+ VCR scart and when played it would over ride the SKY+ output (using passthrough).
    Sorry if it doesn't work but a lot of it is trial and error:)
