Sky DVD player hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by MrX, Dec 2, 2003.
  1. MrX
    MrX
    Does anyone know the make of the Sky DVD player that is used in its Home Cinema System? Also, is there a multi region hack for it?
    Cheers :)
  2. Plasma Fan
    Plasma Fan
  3. Plasma Fan
    Plasma Fan
    Sorry mate, I'm new to this. Not sure if the link worked but I've copied the instructions for you.
    Turn the DVD on, press to DVD mode, make sure there is no disc in the drive, press 1 6 7 1 9, press okay when the hidden configuration menu screen pops out, press 0 for all codes, press exit.
  4. MrX
    MrX
    Thats brilliant - thank you very much :) It works a treat :)
    Cheers :)
