Sky drops a high definition bombshell
Discussion in 'Projectors, Screens & Video Processors' started by bullyx, Dec 4, 2004.
  1. bullyx
    bullyx
    Nov 23, 2004
    26
    Glasgow
    Follow the link below to read more about Sky bombshell concerning HDCP
    http://www.homecinemachoice.com/cgi-bin/shownews.php?id=7231
    I'm looking to buy my first pj, was going for 4805, but issue with screen size, now after reading the info on the news link above yet another thing to take into account, anyway hope the above helps some of you
  2. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    201
    +6
    Thanks for that...probabally the most important post this week....even my new Sony receiver now appears out of date...and I thought component video would have a reasonable lifespan......on the verge of getting a projector so will lhave to watch specs carefully so as to future proof
    Dave
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I wouldn't call it a bomb-shell to be honest, in the US some cable companies introduced HDTV allowing an analog feed to the TV but have announced next June they'll disable analog and only allow protected digital.
  4. grey torq
    grey torq
    Jul 13, 2002
    394
    28
    +26
    For a non-techy out of touch does anyone know if the Panny AE700 HDMI connector is compatible with this HDCP thingy?
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Yes, HDMI is backwards compatible with DVI+HDCP .. the other way round isn't guaranteed to work though. Actually, unless Sky have stated that it will definitely be DVI(HDCP) I'd have thought itmore likely by then they'd be using HDMI.
  6. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    The 4805 DOES support HDCP encrypted signals via DVI/HDMI
  7. Dwayne Dibley
    Dwayne Dibley
    Dec 1, 2004
    934
    Right Here, Right Now
    +313
    what screen size issue?? (the 4805 is on my shortlist of potential pj)
  8. maverick177uk
    maverick177uk
    Jun 1, 2004
    4,913
    +867
    ^^^ don't go for 92" unless you have a throw of at least 12 foot.
  9. Botang
    Botang
    Dec 31, 2004
    2
    Sorry to bring this one up again but I was just about to put my hand in my pocket to buy a Panny AE700 when I followed a link to the plasma section
    http://www.avforums.com/forums/showthread.php?t=168496&page=1&pp=15
    It gets quite technical and they completely lost me :rolleyes:
    Should I be concerned about the implications of SKY HDTV???
    Will the AE700 be ok or will it have the same issues as the Panny Plasmas :lease:
  10. Mr_Sukebe
    Mr_Sukebe
    Mar 10, 2004
    2,397
    London
    +212
    I've been told that the AE500/AE700 will work fine with HDTV broadcasts, nice!
  11. The Nightfly
    The Nightfly
    Aug 31, 2002
    821
    The New Frontier
    +24
    Having a DVI-HDCP or HDMI connector on the projector is no guarantee that it will be compatible with Sky's proposed high definition service. What you also need to ensure is that the projector will support 720p and 1080i resolutions on the digital inputs at 50Hz.
    Its the lack of 50Hz compatibility on DVI and HDMI with most plasmas that is causing the concern.
    Allan
  12. Botang
    Botang
    Dec 31, 2004
    2
  13. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
  14. tomos
    tomos
    Oct 3, 2004
    149
    nooo, i want the ae700, but want high def when it comes out too :(
  15. grey torq
    grey torq
    Jul 13, 2002
    394
    28
    +26
    The table in my manual for the AE700 clearly states 50Hz 1080i & 720p support to the HDMI input. I do not however have any means to check that it really does do this.
