Sky Dolby Digital 5.1 broadcasts amp setting?
Discussion in 'Sky Digital TV Forum' started by Swordfish, Jul 12, 2004.
  1. Swordfish
    Swordfish
    May 31, 2004
    2,952
    Cheltenham
    +557
    When Sky Movies shows a film is in Dolby Digital 5.1, what setting do I set my amp to? It automatically selects the Dolby Digital or DTS Soundtrack when playing DVD's.
  2. Fatti
    Fatti
    Oct 22, 2002
    665
    Worcester
    +40
    Assuming you have Sky+, your amp should automatically detect the 5.1 broadcast as long as connect the digibox to the amp using the optical output.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You may have to manually assign the optical input used on the amp to the associated input device so that the amp knows to look at that input when you choose Sat/AUX input etc on the remote or front panel. I suspect you've already done that for your DVD input:)
    Once that is done the amp should then auto select the format when it looks at the optical input and switch to DD as and when needed.
  4. Swordfish
    Swordfish
    May 31, 2004
    2,952
    Cheltenham
    +557
    Thanks for your prompt reply. I have no digital out on my Sky box as it is not Sky+, so I suppose my only option is to invest in Sky+!
  5. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    You're right there. The only way to get the DD5.1 for Sky Movies 1, 2 , and 3 is to get SKY+ and connect to your amp using an optical cable.
    Another way for SKY to extract more money....but SKY+ is superb!!!
  6. ReHaBWales
    ReHaBWales
    Jan 7, 2003
    112
    16
    Sky+ is good...pity the EPG sux. We need a Tivo EPG on the Sky+ :)
  7. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    the sony has an optical out if you dont want to go towards sky+
  8. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Alas TIVO would want paying for the license to use the software and a continuing monthly payment for each and every SKY+(TIVO equipped) unit that SKY sold:)
  9. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    No use for DD 5.1 audio though.
    SKY really should offer a standard digibox with a fully enabled optical output.
