Sky + Does programming survive Power cuts?
Discussion in 'Sky Digital TV Forum' started by rnjones, Aug 10, 2002.
  1. rnjones
    rnjones
    Hi, after seeing posts about manual recording on Sky + I am much closer to getting one. However there is one thing I need to know.
    If you have a powercut does Sky + remember the EPG and timer settings you have made?
    I seem to get a lot of short power outages. One of my VCRs remembers, the other doesnt and it really bugs me.
    As it has a hard disk I assume it will pick up where it left off.
    Also
    Does the Optical output sound better than normal stereo outputs on non DD channels?
    Where can I get a Free To Air card for my old Panasonic digibox?
    Thanks Rog
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Yes the Planner entries survive a power failure.
    If there is a power cut during a recording when the power returns the recording will continue assuming the planner start/stop time is still valid.
    I would probably say yes the optical output does sound better for stereo material but it's a subjective opinion at best. I still prefer the phonos for outputting a Dolby Prologic soundtrack to my amp.
    BBC FTV smartcard details here.......FTV
