SKY+ Dissappearing Recordings!
Discussion in 'Sky Digital TV Forum' started by chrisj, Dec 29, 2002.
  1. chrisj
    chrisj
    I have been using Sky+ for about six months and have recently noticed that some of the programmes I had stored on disk have just dissappeared from the list of recordings! The disk is not shown as being full either. As a matter of fact I now have a situation where I only have a few recordings listed, but the disk is shown as just 16% free. When you scroll through the list of recordings the yellow bar seems to indicate that there should be somethings like 70% free! It is almost as if the vanished programmes are still on the disk but not listed.
    Any ideas?
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    Watch anything you need then try a Full System Reset.
    Services
    4 - System Set Up
    7 - System Test
    Press 0 + 1 + Select ( Quickly )
    7 - Full System Reset
    Also your earliest recordings will disappear ( especially if viewed ) if you have Disc Space Management set to Auto. You may prefer it set to Manual instead, whereby an on screen prompt appears before deleting to make space.
    Try watching everything then deleting to see how things go.
