Sky+ display problems
Discussion in 'Sky Digital TV Forum' started by lopper_out, Sep 19, 2004.
  1. lopper_out
    lopper_out
    I have an annoying problem that I get a ghosting image going across the screen from BBC one while i am watching other channels. It's at its worst on saturday afternoon's when you can see score's from the football on final whistle going across the screen. I need help!! as it is driving me insane. :zonked:
  2. John
    John
    Dec 13, 2002
    11,393
    +3,024
    Do you have the aerial connected to the digibox? If so disconnect it and see if that helps , it does not have to be connected at all really.I've never had it connected in all the time I've had Sky .
  3. tattyman
    tattyman
    Do you have your tv channel (on the TV, not the Sky box) set to BBC1?
    I used to have this problem with my Panasonic TV and SKY+ box, whatever channel the TV was set to would ghost through underneath the SKY picture (which was coming in through the AV1 SCART socket. The only way I could stop it was to set the TV to Channel 0, which was tuned into my VCR and thus pure black when the VCR was in stand by.
    Then I read an article on a TV installers website that said this was a common problem due to the TV sending it's channel out on the SCART cable on pin 19, and if you snipped pin 19 the ghosting would go away. I did this and, hey presto, no more ghosting.
  4. johndon
    johndon
    Feb 3, 2002
    1,985
    63
    +120
    I had the same problem even though no aerial was connected to the Sky box. I bought a fully shielded scart cable and it solved the problem.
    John
  5. Emm
    Emm
    Jan 9, 2004
    Norfolk
    I've done this too (pin 19 at the 'TV input' end) to cure the 'ghostly' background image - it does work
    :cool:
